The PG 1350 is a lithium ion battery pack that provides 3.7 volts of DC power. It has a capacity of 1350 mAh; hence the model number. These specifications is equivalent to 4.995 watt/hour.
I originally came across this battery pack when I purchase the Akaso Brave 7 LE action camera. Since then, I noticed that it is actually compatible with quite a few other action cams.
Cross-Reference
Want to know more about the Akaso Brave 7 LE? Ready our "Akaso Brave 7 LE Review".
This web page keeps track of all the electronic products that share this battery pack. You are welcome to update this list.
The bottom of this page shows the pin-out of this battery, so you can interface to in with other means. Finally, there is a section for the charger.
The photo below shows the location of the positive and negative pin on the battery pack. There is no indication what the third middle pin is for.
Equivalent pin-out on the charger shown below.
The charger shown below is the one supplied with the Akaso Brave 7 LE. It is a double charging dock. Model SX-50-F01. It accepts 5v input at 2A max. It provide 4.2v output at 0.5A to each of the charging ports.
363 Users Online
